Group: DynoMotion Message: 14685 From: kn6za Date: 5/7/2017
Subject: Re: KMotion/KFLOP Test Version 4.34i - New Screen Editor Capabilitie
   Wow! thanks for all the improvements! The G84 and G95 are great! You have been busy.
   Andrew
Group: DynoMotion Message: 14688 From: kn6za Date: 5/7/2017
   I noticed a couple things in 434i.
  On my system g32 single point threading still does not work with m4 spindle rotation.
   Also in g95 mode, feed will not occur with m4 spindle rotation.
   Both g32 and g95 work fine with m3 spindle rotation.
    Andrew
Group: DynoMotion Message: 14691 From: yanvrno@frontier.com Date: 5/8/2017
Hello Tom
Looking forward to creating my own custom screens. So thank You
But I use mostly # variables in my gcode, and wondered if there was an option/ability to view these in real time. Or is there a way to add a series of dros of the variables in use.
A dro box of the computed variable would confirm for me the data calculated. (I now use Single blocking an unused spindle rotary position to show me the value, example; g0b#105)
Would be great also to have loop index dro to see where I am in a macro call.
My desired screen would include a floating window/sidebar that can be minimized or closed, filled with the chosen variables.
I find that most operations are just repetition of whittling away material, (Turning, Facing, Chamfer's, Radius's, Tapers, Threading, Milling, Profiling, Drill Patterns)
So I have some basic routines Roughing/Finishing that I just edit for the operation and save it as the job name for future reference. Then by using "/" block delete I can turn on and off the macro calls.
Thanks again
Mac
Group: DynoMotion Message: 14696 From: Tom Kerekes Date: 5/8/2017
Hi Mac,
I tried to create such a screen.  See attached Screens, C Programs, and Video explaining how it works.
https://youtu.be/wtiiZ16mkho
On 5/8/2017 6:13 AM, yanvrno@... [DynoMotion] wrote:
Hello Tom
Thanks again
Mac
  @@attachment@@
Group: DynoMotion Message: 14697 From: Tom Kerekes Date: 5/8/2017
Hi Andrew,
Sorry dropped the ball on that one.  I thought that was fixed Years ago but only for Mach3/
Please try this patch for V4.34i
http://dynomotion.com/Software/Patch/Fix_M4_CCWThreading_KMotionCNC_V434i/
    Andrew
Group: DynoMotion Message: 14698 From: kn6za Date: 5/8/2017
  No problem. I will test it out.
  Andrew
Group: DynoMotion Message: 14702 From: yanvrno@frontier.com Date: 5/9/2017
Must be you liked my idea/need, as you sure jumped on creating an example and video quickly, lol
Thank You and Good Job
Are these screens and functions available for all, as I did not find them in the ftp Index of /Software?
Thanks again
Mac
Group: DynoMotion Message: 14703 From: yanvrno@frontier.com Date: 5/9/2017
Opps, my Bad
Never seen the example files at the bottom of the post
Did not realize the screens were just text files.
Sweet!
Mac
Group: DynoMotion Message: 14709 From: kn6za Date: 5/9/2017
   The changes you made took care of both the G32 and G95 issue with M4. Works great.
   Thanks!
    Andrew
Group: DynoMotion Message: 14711 From: TKSOFT Date: 5/9/2017
Thanks for posting back.
On 2017-05-09 11:29, kn6za@... [DynoMotion] wrote:
> Hi Tom,
> M4. Works great.
> Thanks!
> Andrew
